Overheating R22 Compressors.
Old 12-11-2013, 03:54 AM   #1
mbard1914's Avatar
Trade: n/A
Hello All,
Im a lab technician and test HVAC systems in a psychrometric lab and have had a reacurring problem in my cooling equipment in my outdoor (OD)room. When running a LAC(Low Ambient Control) test with my OD room at 25F, my OD cooling equipment shuts off on internal overload with Compressor dome temperatures getting up to 300F before they shut off. I know this is not the best on the compressor would like to get it lower so that they are able to run more efficient and cool my OD room better with out shutting off. They system Im using is a 5-ton R22 system. My condensing coil is a water coil instead of a air coil and my evaporator is a air coil. My compressor also receives no airflow over it so this does not help with it overheating. Any tips or suggestions you may have in getting my Compressors to run without overheating would be much appreciated.
Michael
mbard1914 is offline
Old 12-21-2013, 06:56 AM   #2
Re: Overheating R22 Compressors.
The compressor is a vapor cooled compressor, so it doesn't need any air flow over it.
If your using a standard water cooled A/C condenser to cool your OD room to 25F. Its not getting enough cold refrigerant vapor back to it, to keep it cool.
Does the system have a hot gas bypass to keep the indoor coil from freezing? If so, it may be bypassing too much hot gas. So you may need to add a liquid injector to the vapor line to cool the compressor.
Old 12-21-2013, 08:18 AM   #3
mbard1914's Avatar
Trade: n/A
Thank you for your response.
It is not a hot gas bypass compressor and I feel like I should be able to get them to work without installing one.
I also do not have problems with my evap coil freezing. I just have problems with high SH and them going off on internal overload.
Michael
Old 12-21-2013, 08:31 AM   #4
Michael
Using a high temp/comfort cooling metering device, you will have high SH. If you get the Sh down, you will have freeze up problems. A/Cs are not made to lower a room temp to 25F. So you either have to modify it, or change out compressors on a regular basis as they burn out.
Old 12-21-2013, 08:38 AM   #5
mbard1914's Avatar
Trade: n/A
So by modifying I was looking as changing my cooling TXVs. What would u suggest for modifying it?
Old 12-21-2013, 08:45 AM   #6
Adjustable medium temp TXVs. Along with increased CFM across the cooling coil. To reduce frosting.
Old 12-21-2013, 08:55 AM   #7
mbard1914's Avatar
Trade: n/A
What about changing the system to a different refridgerant. Is there one that could perform better for me?
Another variable to consider is the pin valve on the water coil. What is its roll in this if any?
Old 12-21-2013, 02:08 PM   #8
You would still have a high SH with a different refrigerant. By pin valve, are you referring to a pressure regulating valve.
Old 12-21-2013, 03:45 PM   #9
mbard1914's Avatar
Trade: n/A
Yes that is what I mean by pin valve.
Old 12-21-2013, 05:17 PM   #10
That is to be adjusted to provide proper SC.
Old 12-21-2013, 08:53 PM   #11
mbard1914's Avatar
Trade: n/A
What would be the optimal range to see the sc at when.cooling the room to 25 degrees? If any.
Old 12-21-2013, 10:29 PM   #12
No real optimal. 10 to 12, same as most other med temp coolers.
Old 06-21-2014, 03:32 AM   #13
airtrackinc's Avatar
Trade: airtrackinc
vapor cooled compressor no need of air flow
airtrackinc is offline
Copeland Compressors for Sale jmf346 Business, Marketing, and Sales 2 06-15-2013 06:11 PM
Here are some of the compressors I work with! nH3man HVAC Pictures 4 01-13-2013 04:59 PM
