| Sponsored By: |
Trade: hvac
lennox hp defrost board codes
I have a lennox HP26 with a retrofit defrost control and no code ledger need to know what red and green status lights are
Trade: hvac
Re: lennox hp defrost board codes
Not sure why the codes would change from old board to new board if the new board is for the same condenser. If you dont have the old codes maybe this will help
For original board: LED 1, LED 2, Code Meaning ==================================== OFF OFF Board failure or no power to board ON ON Board Failure Flash ON High Pressure switch open ON Flash Low Pressure switch open On Off Pressure switch lockout Alternating flashes means the unit is in short cycle delay Synchronized flashing means normal operation, power to board, but no call for heating or cooling. |
board, codes, defrost, lennox ![]() |
| New Codes | rmihvacr | Residential HVAC Forum | 1 | 08-12-2012 05:35 PM |
| Speed up defrost cycle on York Guard | crazeehorse | General HVAC Discussion | 3 | 01-07-2012 09:42 PM |
| lennox circuit board | wayne1178 | Residential HVAC Forum | 3 | 06-23-2011 10:57 AM |
| Heat Pump Defrost | cmr_3168 | Residential HVAC Forum | 0 | 01-25-2010 10:00 AM |
| defrost board started a fire | david c h | General HVAC Discussion | 4 | 06-17-2009 11:53 PM |
