Trade: Residential Hvac
Large unit coil stopped up with lent.
Large unit coil 4'x8' slab coil stopped up at sewing plant.
Best way to clean Help Help
Trade: Chill water air handlers, geothermal, Carrier Infinity
Re: Large unit coil stopped up with lent. |
Good Info this should do a better job.
Thanks Gary Montgomery, Al. |
You might shop vac it first and monitor the drain while washing the coil.
Trade: Mechanical contractor
I always use chemicals as a last resort and too much water pressure and you will fold the fins over and wreck your airflow.
Dry brush, vacuum out debris then water is usually the way to go but in the environment you are talking about removal of the coil to clean may be the only effective way to go. Either way the only way you can really know if you are making an impact is to take static pressure readings on either side of the coil to see if you have made any difference. |
Trade: Heating & Air Conditioning
Re: Large unit coil stopped up with lent.Quote:
Contractors Continuing Education (CE) Petro Chemical CE Electrician Online Courses |
The chemicals we have available are an alkine detergent foaming coil cleaner or an acidic coil cleaner. Either one should be used carefully, diluted and not used in windy conditions as anyone on this site can tell you this stuff will ruin your modelling career. I still believe taking the equipment apart and provided you have sufficient water pressure is the way to go.
| package unit dolly | adam | HVAC Tools and Equipment | 9 | 10-15-2011 04:35 PM |
| Need Marlo Coil Decoded | mahatfie | Commercial HVAC Forum | 3 | 05-09-2011 08:24 PM |
| carrier coil problem | able 1 | Commercial HVAC Forum | 1 | 05-30-2010 09:08 PM |
| txv coil temp control? | RoBoTeq | Residential HVAC Forum | 14 | 09-10-2009 11:10 PM |
| Xe 1100 outside unit | cralx2k | Residential HVAC Forum | 15 | 08-07-2009 12:37 AM |
