Help With New Install - General HVAC Discussion - HVACSite
Old 07-14-2018, 06:39 PM   #1
velocitygraphix's Avatar
Trade: Carpenter
Hello everyone, I am building a house and getting ready to put the floors down but wanted to clean the ducts from dust/debris before I proceed. The air handler is installed with 240 power to it. However, the thermostats are currently not on the wall and just the wires coming out and I have tested the voltage. The red wire has 24volts on it. I wanted to run just the fan so it can blow through all the ductwork so it will alleviate the dust cleanout later. I connected the red and green wire together but the fan didn't run. I have checked the air handler and both disconnect breakers are turned on and the LED inside is on. Is there something that needs to be done to get the fan to just run? Does the thermostats need to be installed before i can run the fan? It seems like the handler is getting power to send to the thermostat since it has 24 volts but the fan is not turning on..Any help would be appreciated. Thanks!
velocitygraphix is offline
Old 08-22-2018, 12:14 PM   #2
Faith Heating & Cooling
faithheatingcooling's Avatar
Re: Help With New Install
sounds to me that there is a problem with the wiring at the air handler low voltage or G wasn't ever wired in. Try disconnecting the disconnect to the outside unit and connect the y and r at the tstat. that should run the fan only.
Steve - Faith Heating & Cooling Chicago
faithheatingcooling is offline
Old 10-06-2018, 11:53 AM   #3
How did this work out for you? Curious
