Evaporator coil - General HVAC Discussion - HVACSite
Evaporator coil
Old 08-11-2017, 08:06 PM   #1
Rmoll's Avatar
Trade: Electrican
Evaporator coil
Look to get some help picking the right coil for a ac install.
Oil furnace installed 22 3/8w 20d not much hight Clarence
Installing a Goodman 13 seer 2 ton unit. Can't seem to find a coil to fit the furnace cabinet. Any help would be appreciated.
Rmoll is offline
Old 02-16-2018, 03:49 PM   #2
madjr12's Avatar
Trade: Commercial/Industrial Service Technician
Re: Evaporator coil
Well many years ago, when I was a residential installer, we would always install the coil at least 6 inches above the oil furnace cabinet. This would ensure the hi heat from the oil furnace wouldn’t melt the cheap plastic condensate pan. However, with a height restriction , this may not be possible. If your plenum has 1 main trunk duct coming off of it, is it possible to install a vertical coil in the main trunk before any branch duct?
Sent from my iPhone using Tapatalk
madjr12 is offline
Old 02-16-2018, 04:25 PM   #3
madjr12's Avatar
Re: Evaporator coil
madjr12 is offline
Old 02-26-2018, 09:39 AM   #4
droopylee95's Avatar
Trade: service tech work mainly on commercial rooftop equipment an refrigeration
Re: Evaporator coil
If you have a wholesale house that Carries heil or icp (southern refrigeration here) you can get a N coil that pretty much only thing we used on fossil fuel or trailer furnaces. They usually fit well an round 14 to 16 inch tall.
Just make sure you get all sides sealed. Installers left one side with no shelf to set on an air was bypassing coil.
Sent from my SM-G930R4 using Tapatalk
droopylee95 is offline
