Blended refrigerant separating - General HVAC Discussion - HVACSite
Old 03-31-2018, 09:43 AM   #1
anthonylpereira's Avatar
Trade: commercial hvac
I recently came across a cooler not keeping temp. It had a box section and a rail section with 2 stats and 2 solenoid. It had 1 compressor and charged with 24 oz of 404. Box temp was good, rail wasn't. T stat was calling, solenoid had power. My pressures were good also. A previous tech left a dye sticker on the unit indicating a leak at some point. My boss believes that the unit had a leak and the refrigerant separated due to the fact that 404 is a blend. Theory being only one gas leaks thus altering the refrigerant blend. Any truth or input?
Sent from my SM-G920V using Tapatalk
anthonylpereira is offline
Old 03-31-2018, 09:47 AM   #2
Re: Blended refrigerant separating
Also the evap were cold plates (no fan). I left it with the theory that the evap was partially frozen. I turned down a pegged stat and told them to leave it unplugged for 24 hours. I haven't heard back.
Old 04-02-2018, 09:27 AM   #3
xtrmref64's Avatar
Trade: 18 years experience with commercial HVAC systems, supermarket refrigeration, ice machines, restaurant equipment, residential HVAC, process piping, chillers
Check to make sure you are properly charged first, clean condenser coil, then check superheat on the rail evaporator coil. Could be a bad TXV. Since you only have 24 oz of R404a you may test your boss's theory by recovering the remaining refrigerant which will tell you if you were charged correctly to begin with. Replace the filter drier and triple evacuate with nitrogen. Charge to nameplate with virgin R404a. See what's going on after that.
Sent from my SM-G550T using Tapatalk
xtrmref64 is offline
