410a low suction pressure high head pressure - General HVAC Discussion - HVACSite
Old 06-15-2013, 12:09 AM   #1
Dsmall07's Avatar
Have a 2 ton 410a hp running 75 suction & 365 head pressure od temp is 79 degrees suction line temp is 69 and air coming out the vents is 68 degrees and its 77 degrees in house.. Anyone have a clue what my problem is ?????
Dsmall07 is offline
Old 06-16-2013, 07:57 AM   #2
Re: 410a low suction pressure high head pressure
A restriction in LLFD if its outside the condenser, or at the metering device. Could also be a pinched liquid line.
Old 06-17-2013, 11:58 AM   #3
Dsmall07's Avatar
Liquid line isn't pinched do u think I should change the Txv and the LLFD
Dsmall07 is offline
Old 06-17-2013, 04:32 PM   #4
You can replace it also. or test to see if its working first before replacing it.
Old 06-18-2013, 09:39 AM   #5
Dsmall07's Avatar
How do I go about testing it iv never had to test or replace one b4
Dsmall07 is offline
Old 06-18-2013, 03:49 PM   #6
While the system is running, place the bulb in ice water, should see the suction pressure drop. Then place the bulb in hot water, should see the suction pressure rise. if it does both as I said, its good.
Old 06-19-2013, 02:35 AM   #7
Dsmall07's Avatar
Ok thank u so much ill try that Friday and let u know what happened
Dsmall07 is offline
High head pressure fluctuating on a new 410a install popeyess Residential HVAC Forum 4 05-30-2013 12:11 PM
normal suction low head pressure briantaddeo Residential HVAC Forum 8 01-20-2013 09:23 PM
high head pressure low suction tcbaker72 Residential HVAC Forum 54 11-28-2012 04:45 PM
High head pressure fluctuating on a new 410a install popeyess General HVAC Discussion 8 06-26-2012 10:39 PM
high head pressure low suction whitelaker General HVAC Discussion 6 07-04-2011 08:16 AM
