R22 Replacement - HVAC Material and Products - HVACSite
R22 Replacement
Old 04-06-2012, 12:31 PM   #1
Maxwell HVAC's Avatar
Trade: Joe Darby
R22 Replacement
Hello
R22 is over $350.00 for 30lbs tanks. Any solutions out there.
I see this new item by a company called Ecofreeez. EF-22a.
They claim thats it's a drop in replacemnet for R22 and can be used to top off and/or replace. Its made of hydrocarbons.
Very reasonable in price.
Any thoughts aout there will be greatly appereciated.
Joe Darby
Maxwell HVAC is offline
Old 04-06-2012, 12:56 PM   #2
HD HVAC's Avatar
Trade: Refrigeration
Smile
Re: R22 Replacement
Great Stuff!! At first I couldn't figured out the 30lb equivalent thing. But when I got it I realized that the reason they do that is because you will use less. For every 2.5 pounds of R22 I took out I only had to put in one pound of EF-22a. It worked like a charm and at lower amperage!
HD HVAC is offline
Old 05-02-2012, 05:54 AM   #3
Re: R22 Replacement
The EPA has not approved propane to be used in central cooling systems.
Old 08-07-2012, 06:30 AM   #4
HVAC professional
moshei's Avatar
Re: R22 Replacement
Can you tell me some further reason why it's not approved?
moshei is offline
Old 08-07-2012, 04:24 PM   #5
Re: R22 Replacement
No, I can't.
Old 03-04-2013, 06:09 PM   #6
Best HVAC Parts and Goods
Ingram's water & Air's Avatar
Trade: Ingram's Water And Air Equipment
Re: R22 Replacement
Unfortunately for the environment, releases of R-22, such as those from leaks, contribute to ozone depletion. In addition, R-22 is a greenhouse gas and the manufacture of R-22 results in a by-product that contributes significantly to global warming.
Also there are several reasons behind the Ban on R22. Such as recycling process for R22 etc. We may expect the new R22 based products may be available after 2020 hopefully.
However existing units can be repaired using R-22. Cheers
Ingram's water & Air is offline
Old 05-09-2013, 09:33 AM   #7
cliffanator85's Avatar
Trade: HVAC Service Tech
Re: R22 Replacement
If you look at the MSDS sheets on this stuff it is 95% propane/butane
cliffanator85 is offline
Old 12-11-2013, 06:38 PM   #8
NationalAirWarehouse's Avatar
Trade: Other
Re: R22 Replacement
While R22 is very costly and not that good for the environment, its currently the only solution available that wont void the warranty. While the replacements do seem to be a promising solution for the future, unfortunately most manufacturers will void the warranty if anything other than R22 is used.
I have heard from several contractors that there might also be compatibility issues with some of the replacements as well. While it may very well just be speculation, some have stated that the replacements do not seem to perform as well as the actual R22.
Hopefully manufacturers will catch on and allow the use of the more eco friendly and lower cost refrigerants soon, as this would also help speed up the phasing out of the old R22 systems. Hope this answer helps!
Wholesale AC & Heating Equipment
http://www.nationalairwarehouse.com/
NationalAirWarehouse is offline
Old 11-10-2014, 08:09 AM   #9
SophiaM's Avatar
Trade: 1711
Re: R22 Replacement
@beenthere how comes
EPA has not listed any flammable hydrocarbons1 as acceptable substitutes for use in air conditioning equipment to date; however, EPA has listed a number of flammable hydrocarbon refrigerants as acceptable substitutes for specific refrigeration uses, including:
butane, propane, propylene, Hydrocarbon Blends A and B (trade names OZ-12 for blend A; and HC-12a and DURACOOL 12a for blend B) in industrial process refrigeration;
isobutane (R–600a) as acceptable, subject to use conditions, in new household refrigerators, freezers, and combination refrigerators and freezers;
propane (R–290) as acceptable, subject to use conditions, in new retail food refrigerators and freezers (stand- alone units only); and
R-441A, a hydrocarbon refrigerant blend consisting of ethane, propane, isobutane, and n-butane (trade name HCR-188C), found acceptable subject to use conditions in new household refrigerators, freezers, and combination refrigerator/freezers.
EPA notes that the listings for household and commercial refrigerators and freezers apply only to equipment that was specifically designed to be used with that refrigerant. The Agency has not found hydrocarbon refrigerants acceptable for use in refrigerators that were originally made for a different, non-flammable refrigerant.
source - http://www.epa.gov/ozone/snap/r22a.html
SophiaM is offline
Old 11-10-2014, 08:30 AM   #10
SophiaM's Avatar
Trade: 1711
Re: R22 Replacement
isobutane (R600a) as acceptable, subject to use conditions, in new household refrigerators, freezers, and combination refrigerators and freezers;
propane (R290) as acceptable, subject to use conditions, in new retail food refrigerators and freezers (stand- alone units only); and
SophiaM is offline
Old 01-19-2015, 11:01 AM   #11
akachilliewillie's Avatar
Re: R22 Replacement
How do u fix a leak with a torch safely if residual propane is present? With a very long torch tip?lol
akachilliewillie is offline
Old 03-26-2016, 11:39 PM   #12
heatingrepairchicago's Avatar
Re: R22 Replacement
there are a bunch of replacements for 22 the ef22a is fine just a watered down version of 22 just like the rest of them. just be careful when brazing with residue in the lines as it is very very flammable.
Chicago HVAC - Miami HVAC - GO Blackhawks!
heatingrepairchicago is offline
Old 07-06-2017, 09:17 PM   #13
infinair's Avatar
Trade: 19901116
Re: R22 Replacement
I know a very reliable Chinese fans manufacturer - INFINAIR www.industrialaxialfan.com
It has all kinds of fans, industrial axial fans, centrifugal fans, inline fans, roof mounted fans, mixed flow fans, sidewall exhaust fans and so on. It can match all your need.
infinair is offline
r22, replacement
R22 replacement Maxwell HVAC Commercial HVAC Forum 4 09-13-2015 07:27 AM
Furnace replacement New Age Hvac HVAC Pictures 2 01-23-2015 03:51 PM
R22 Replacement Maxwell HVAC Residential HVAC Forum 18 05-16-2013 07:47 PM
Boiler replacement Dennis Harbison General HVAC Discussion 1 08-17-2011 02:52 AM
Replacement for a TAC T155-010 GregoryV Residential HVAC Forum 6 05-18-2011 12:54 PM
