Beckett Genisys Primary Control
Old 03-22-2009, 01:08 PM   #1
NHMaster3015's Avatar
Met with the Beckett Rep on this product last Thursday at a NAOSHM meeting. Very impressive oil burner primary control. Priced about the same as Honneywell with ten times the features. Should make troubleshooting a breeze as the control logs the last 20 burner cycles including cad cell ohm readings. voltage during run, cycle times for post and pre purge (and its adjustable) Amazing technology.
The Beckett GeniSys™ Advanced Burner Control is a 120 Vac primary safety control for residential and light commercial oil burners used in boiler, furnace, and water heater applications. The GeniSys™ is used with a suitable cad cell flame sensor to control the oil burner motor, igniter and optional solenoid valve. It has 24 Vac thermostat inputs compatible with both on/off and power stealing thermostats. It can provide interrupted or intermittent duty ignition, and has a 15-second lockout time.
NHMaster3015 is offline
Old 03-22-2009, 09:53 PM   #2
Trick1's Avatar
Re: Beckett Genisys Primary Control
I absoultley love these controls! If you purchase the contractor tool, you can check out the lockout history as well as set the parameters on which it operates.
Trick1 is offline
Old 03-24-2009, 02:57 AM   #3
pcplumber's Avatar
I thought oil went out just after coal furnaces. They actually has oil burning furnaces in homes in Los Angeles. I go under several homes and there are pieces of the furnaces, but I never saw a pipe that carried the oil, nor an oil storage tank.
pcplumber is offline
Old 03-24-2009, 11:17 AM   #4
protech's Avatar
I've seen many empty tanks and crimped of copper lines but never an active oil burner system.
protech is offline
Old 03-24-2009, 06:14 PM   #5
Here in the north east, probably 60 to 70% of all heating systems are oil fired.
Old 05-31-2009, 03:12 PM   #6
East coast uses lots of oil for heating.
A lot of oil delivery companies around here.
Old 06-16-2009, 12:28 AM   #7
hvactech's Avatar
Trade: commercial/residential HVAC service/installation 20+years
Send a message via AIM to hvactech Send a message via Yahoo to hvactech
Not too many oil burners left here in MI. We only service a small handful each season.
hvactech is offline
Old 07-08-2009, 12:38 AM   #8
I don't do any small stuff like that but if I did that looks like a great option. I work on a good amount of PowerFlame dual fuel units but they tend to be in the 2+mbtuh size.
Old 10-20-2011, 01:39 AM   #9
Robbyt69's Avatar
Trade: technician
Beckett really had their act together with the design of this control. What a great addition to the oil field...
Robbyt69 is offline
