HVAC Site - Professional HVAC Contractors Forum
CLICK HERE AND JOIN OUR COMMUNITY TODAY...IT'S FREE!
Go Back   HVAC Site - Professional HVAC Contractors Forum > HVAC Tools, Products & Safety > HVAC Tools and Equipment
Reply
Old 07-04-2009, 04:16 PM   #1
Default vacuum pumps
I heard rotary vane type wasn't the best way to go. I know I want a 2 stage,lowest micron rating, 7 to 10 cfm pump but is richie,jb, and yellowjacket my only options or does anyone have other opinions and good reviews on vacuum pumps. Thanks---Steve Meyer in Louisville Ky.
smpha8 is offline   Reply With Quote
Join HVAC Site
Join the #1 HVAC Forum Today - It's Totally Free!
HVACSite.com - Are you a Professional HVAC Contractor? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's the leading place for HVAC Contractors to meet online. No homeowners asking DIY questions. Just fellow tradesmen who enjoy talking about their business, their trade, and anything else that comes up. No matter what your specialty is you'll find that HVACSite.com is a great community to join. Best of all it's totally free!
Join HVACSite.com - Click Here JOIN FOR FREE
Old 07-04-2009, 08:21 PM   #2
wholesalerep
RoBoTeq's Avatar
What kind of work do you do? If residential, then a 5 cfm pump is more then enough.
There are several reasons to not evacuate too fast or too deep. Too fast can freeze vapor molecules which then causes them to take longer to evaporate by sublimation. Below 250 micron oil boils. This is fine if you are evacuating a new line set with new coil, but if you are evacuating an existing coil or an entire system, you are going to be boiling off oil below 250 micron. You will know when this happens as the oil vapor starts bellowing out of the pumps exhaust.
RoBoTeq is offline   Reply With Quote
Old 07-05-2009, 01:00 AM   #3
Thanks for the info. I do more residential than commercial but really want a higher cfm pump for installs (lineset and coil) and I'll use my 6 cfm for 2 to 5 ton existing system service work. I also know the oil in the R-410-A systems is quite different than R-22 systems. I only install 410 systems now because of the code changes as of Jan. 1st 2010. I need a higher cfm pump to get the 500 micron draw on new installs. It seems to take too long with my 6 cfm,2 stage pump. I was told the JB-DV285N pump is a good reliable unit.
Old 07-05-2009, 12:05 PM   #4
wholesalerep
RoBoTeq's Avatar
If your 6 cfm pump is not pulling below 500 micron evacs in a timely manner, there is something wrong with either the pump, your lines, connections or something in the way you are evacuating. Are you changing the pump oil regularly and keeping the oil level correct?
Old 07-05-2009, 10:53 PM   #5
My 6 cfm pump is the problem. Its 12 yrs. old now and while pumping a 4 ton system down (condensing unit,lineset and coil), I let it run for about 90 minutes. I checked it then at 460 microns and came back 30 minutes or so and it was 395 microns. I turned it off and checked the oil,connections, etc. I started pumping it down again and it only took 20 more minutes to reach 500 microns. I didn't change oil or anything else but let it cool off before I ran it again. My local distributer said when it warms up after running for a while is when the seals in the pump start to fail on older pumps. I think I'll just get a 7 cfm 2 stage and use it for all my applications. I do change the oil after all repair or contaminated system pump downs and might let it go several times before changing oil if I use on an install job. Do you have an opinion on a good pump? Thanks! Steve Meyer (master hvac contractor) in Louisville Ky.
Old 07-06-2009, 12:09 AM   #6
wholesalerep
RoBoTeq's Avatar
I do pump oil changes pretty much the same way. I have always used Robinaire pumps, but I'm sure there are other good ones.
Old 07-06-2009, 09:48 AM   #7
I have always had good luck with Robinaire as well. I bought a pretty expensive Yellow Jacket pump a while ago and it seemed to have leaking seals from the get go, it was fixed twice under warranty and leaked again, it's now a door stop in my garage.
mechanicalDvr is offline   Reply With Quote
Old 07-06-2009, 05:24 PM   #8
wholesalerep
RoBoTeq's Avatar
That's a shame. Yellow Jacket makes quality products in many other products.
Could have been a bad unit or even one of a bad batch. I have a piece of crap Honda lawn mower, and I know that Honda makes good mowers.
Old 07-06-2009, 06:33 PM   #9
I currently have 4 pumps. I'd rate them in the following order:
Yellow Jacket
JB
Robinaire (the older style)
Harbor Freight (don't laugh, I don't use it for HVAC)
I thought I read that Robinaire is now manufactured in China.
henny is offline   Reply With Quote
Old 07-06-2009, 10:28 PM   #10
wholesalerep
RoBoTeq's Avatar
Yellow Jacket
JB
What isn't made in China any more? I'd be afraid of having another child for fear he'd come out Chinese
Old 07-08-2009, 12:29 AM   #11
Well as long as he didn't have heavy metals in his blood you'd be ok.
Old 07-09-2009, 12:20 AM   #12
wholesalerep
RoBoTeq's Avatar
Reminds me of Mr. Wong who's Chinese wife had a Black baby. Mr. Wong decided to name the baby Sum Ting.
Old 07-11-2009, 12:21 AM   #13
DVR… I don’t know if this could be related the issue you’re having with your YJ pump, but it’s just something to check on if you haven’t already, as it could be why it’s not pulling down properly.
There was an omission in the YJ users manual that was supplemented with a red toe tag in the box for the older SuperEvac pumps.
The thing with YJ, at least with the older 6 CFM SuperEvac, is that the oil level has to be checked and adjusted after you start the pump. If you change the pump oil and just fill it to the line in the site glass, it’s not full. You need to run the pump and add oil until it is up to the fill line in the site glass with the pump running.
Hopefully, this is all that's wrong with it.
DuMass is offline   Reply With Quote
Old 07-11-2009, 01:34 AM   #14
[quote=RoBoTeq;972]There are several reasons to not evacuate too fast or too deep. Too fast can freeze vapor molecules which then causes them to take longer to evaporate by sublimation. quote]
I may be all wet here, but I seem to recall that keeping the gas ballast valve open longer could also help prevent a larger CFM pump from pulling a system down to quickly, as well as it’s intended function, that being to help prevent contamination of the pump oil from moisture in the system being evacuated.
Old 07-11-2009, 11:58 AM   #15
wholesalerep
RoBoTeq's Avatar
[quote=DuMass;1308]
I've only ever used the gas ballast valve to open for easier startups and to close on shut down to relieve pressure. Outside of that, I haven't thought much about the function of this device.
Old 08-08-2009, 07:58 PM   #16
1 CFM per 7 ton, is all you need.
If your current pump is worn out. Still don't need a larger one. One of the same size will pull down faster then your worn out one.
beenthere is offline   Reply With Quote
Reply
Top of Page | View New Posts
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
HVAC Site © 2008 - 2009 The Building Network LLC
