How to adapt an equipment to convert from R-22 to R 410A
Old 10-21-2010, 02:19 PM   #1
Maintenance HBP's Avatar
Trade: technical
Cool
Hi there.
I work for a company that uses R-22 to regrigerate a "cold room". Operation temperature is 32 °F (0°C) approximately.
Its system works with a remote condenser.
To be clear, I am going to divide the system in two parts: the condenser unit (which includes heat exchanger, compresor unit, filter, etc...) and the rest of the system (evaporator and expansion valve)
I would like to change the type of refrigerant from R - 22 to R-410 A. However, it is stated that you have to employ some modifications to the system. My concern is not about the condenser and compressor, because we are going to buy it, it comes with the technical requirements and specification. I would like to know if we have to change the evaporator and the expansion valve.
Thanks a lot for your help!!!!!!!!!!!!!!!!
Maintenance HBP is offline
Old 10-21-2010, 10:06 PM   #2
Re: How to adapt an equipment to convert from R-22 to R 410A
You may be able to replace the R-22 expansion valve to a 410A type you need to check with the air handler/coil mfg.
The refrigeration lines have to be brazed not soft soldered.
the system oil needs to be flushed they have flush kits for that.
You may find it cheaper to replace the coil and refrigerant piping. Make sure the pipe sizes are correct for the new refrigerant.
Old 10-26-2010, 04:29 PM   #3
You cannot convert R22 systems to 410A. R 410 are designed completely different than R22 and operate at a much higher pressure. The displacement of a 410A system is less than R22 because 410A absorbs more heat per pound than R22.
Old 10-26-2010, 11:52 PM   #4
The way I read what he is doing is replacing the condenser that is R-22 to a new condenser 410A and wants to know if he can convert the air side to operate on 410 A.
I don't think he is trying to just covert from R-22 to 410A on an existing system.
Old 10-27-2010, 03:40 AM   #5
It was not 100% clear....the evap has to be cleared for use with 410A from the mfg. And I do not see that happening.
Old 10-27-2010, 10:09 PM   #6
jpsmith1cm's Avatar
Trade: Supermarket Refrigeration
R-410 is generally not used as a medium or low temperature refrigerant.
It would be MUCH more common to see R404a in an application like you are describing.
If it is environmental regulations that you are concerned about, there are retrofit refrigerants available for applications like yours.
jpsmith1cm is offline
410a accident... heating_seattle Residential HVAC Forum 17 08-14-2011 05:04 PM
410a Marty General HVAC Discussion 12 09-30-2010 05:13 AM
Why Maintenance is so important for air conditioning as well as heating equipment? JackClay Commercial HVAC Forum 0 08-31-2010 07:51 AM
Sizing equipment linebacker Residential HVAC Forum 5 06-21-2010 10:46 AM
heat load soft ware for equipment sizing hvaclover Residential HVAC Forum 31 08-08-2009 09:45 PM
